Release ASUS RT-AX92U Firmware version 3.0.0.4.388_23749 (2025/09/03)
fruitcornbread
Version 3.0.0.4.388_23749
66.69 MB
2025/09/03
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum of 10 characters, including at least one letter, one digit, and one special character; disallows consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
ZIP SHA-256 : 82293E37E14D407FD0502E60FEBE18EB2D48803DCC74FA26CA6B864E9BAECF70
FW SHA-256 : 14bb2febb0f2418fb42df461b74732b1adbe67520eac145ecc61f643da82e5b6
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX92U/FW_RT_AX92U_300438823749.zip?model=RT-AX92U
