fruitcornbread
Version 3.0.0.4.388_23763
66.68 MB
2025/10/27
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Fixed a privilege escalation vector in the IFTTT token exchange mechanism.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
ZIP SHA-256 : BE28C7FB6C27B4940B3CC13BC64046F41CCC3F31466D4996CCE8211845F00C39
FW SHA-256 : 71de54de5ed992592f3163200895477c6d4f5be7472e138ad9033684458f56e3
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX92U/FW_RT_AX92U_300438823763.zip?model=RT-AX92U
www.asus.com
66.68 MB
2025/10/27
RT-AX92U|WiFi Routers|ASUS Global
ASUS gaming routers provide the very best gaming experience, with an arsenal of features and tools designed to improve online gaming performance and give you the competitive edge you need to win.
www.asus.com
