fruitcornbread
Version 3.0.0.6.102_38984
65.17 MB
2025/08/11
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum 10 characters with at least 1 letter, 1 digit and 1 special symbol, and no consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
Bug Fixes:
- Fixed abnormal client list.
- Fixed abnormal GUI behavior of Wireguard VPN.
- Fixed USB internet backup conflict with main WAN.
- Fixed abnormal WAN detection while AiDetection is enabled.
- Improved AdGuard DNS GUI issues.
- Fixed IPv6 related issues.
- Improved USB tether compatibility for pixel phones.
ZIP SHA-256 : 3C53536D9577B7E128DD2FF5EEFCA657BFA6B100AF8A73C10904A78B6BCAB402
FW SHA-256 : ac6df3c06d2d7b6eedc4fc751a82c0339f34c067d773940e684c0fdeacea3707
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-BE86U/FW_RT_BE86U_300610238984.zip?model=RT-BE86U
www.asus.com
65.17 MB
2025/08/11
System Improvements
Bug Fixes:
RT-BE86U|WiFi Routers|ASUS Global
Dual-band WiFi 7 router with speeds of up to 6800 Mbps, support 4096-QAM, Multi-link operation (MLO), 10G port, subscription-free network security and comprehensive VPN features
