fruitcornbread
Version 3.0.0.6.102_37839
65.99 MB
2025/05/05
Bug Fixes and Enhancements:
1. Improved compatibility with IoT devices on WPA2/WPA3 networks.
2. Enhanced the stability of remote connections.
3. Resolved an issue with the WiFi scheduler.
4. Improved Parental Control scheduling with support for SDN clients.
5. Fixed an issue causing Movistar IPTV to malfunction.
Security fixes:
1. Implemented a security patch to address an OpenVPN issue.
ZIP SHA-256 : A5D88BE35D5E5400C87D7FD71C72B67AC79F1962015C592C452F937C2D8EA8CC
FW SHA-256 : d6e4db23fede7e5e00a3a898fbb78b7e4371b32885fe0f5d64059dc4f3b09903
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-BE96U/FW_RT_BE96U_300610237839.zip?model=RT-BE96U
www.asus.com
65.99 MB
2025/05/05
Security fixes:
RT-BE96U|WiFi Routers|ASUS Global
Discover RT-BE96U's cutting-edge WiFi 7 router, featuring 320MHz bandwidth, Multi-link operation, dual 10G ports & comprehensive VPN – upgrade your tech experience!
www.asus.com
