fruitcornbread
Version 3.0.0.6.102_38984
65.3 MB
2025/08/26
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum 10 characters with at least 1 letter, 1 digit and 1 special symbol, and no consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
Bug Fixes:
- Fixed abnormal client list.
- Fixed abnormal GUI behavior of Wireguard VPN.
- Fixed USB internet backup conflict with main WAN.
- Fixed abnormal WAN detection while AiDetection is enabled.
- Improved AdGuard DNS GUI issues.
- Fixed IPv6 related issues.
- Improved USB tether compatibility for pixel phones.
ZIP SHA-256 : 5053EDA9F0D32C3E02FEA0EC2747CFF6D5002AFA68DDE9332D1C347AE88E58A0
FW SHA-256 : 399acac2a32213dbf538f4d26bdd672461be2ffa18c46bd241bfe7eaab1b8064
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-BE96U/FW_RT_BE96U_300610238984.zip?model=RT-BE96U
www.asus.com
65.3 MB
2025/08/26
System Improvements
Bug Fixes:
RT-BE96U|WiFi Routers|ASUS Global
Discover RT-BE96U's cutting-edge WiFi 7 router, featuring 320MHz bandwidth, Multi-link operation, dual 10G ports & comprehensive VPN – upgrade your tech experience!
www.asus.com
