Asus RT-N66R Dual-Band Wireless N900 Gigabit Router
RTN
RT-N66R Dual-Band Wireless-N900 Gigabit Router
Incredible Performance with Incredible Control
  • The ASUS RT-N66R dual-band wireless-N900 gigabit router delivers incredible performance and coverage range.
  • With new ASUSWRT UI, quickly setup your network, customize user access, and monitor signal strength.
  • Following the award-winning RT-N56U, the RT-N66R increases Wi-Fi speed for both 5 GHz and 2.4 GHz
    transmission by 50% up to 900Mbps that makes it ideal for bandwidth demanding tasks such as 3D HD
    video steaming, multiplayer gaming, USB hard drive file sharing, and USB connected printer sharing.
  • Built-in Wi-Fi amplifiers make the RT-N66R the perfect wireless router for larger,
    multi-level homes and buildings with signal range that reaches virtually any area.
  • 2.4 GHz and 5 GHz Concurrent Dual-Band Transmissions for Strong Signal Strength
    and Ultra-Fast Connection Rates up to 900Mbps
  • Gigabit Ethernet Ports for the Fastest, Most Reliable Internet Performance
  • Download Master for Wireless Data Storage and Access to Router-Connected USB Storage Devices
  • Expanded Wireless Coverage with Detachable High-Powered Antennas
  • File Sharing, Printer Sharing, and 3G Sharing via Two Multi-Functional Built-in USB Ports
  • ASUSWRT Dashboard UI for Easy Setup, Signal Monitoring, and Network Application Control
http://www.asus.com/Networks/Wireless_Routers/RTN66R/ :cool:
Strange but I cannot find any difference between the RT-N66R and the RT-N66U. Am I missing something?
Works w/ RT-N66U Firmware
I was able to load the latest Shibby TomatoUSB firmware for the RT-N66U onto my RT-N66R. Everything appears to be running just fine.
Tomato actually reports it as an RT-N66U now.
