Asus RT-n66u, Asuswrt-Merlin, OpenVPN with HIDEME.RU
Kondratenko
Hello!
Help, please.
I need to configure the router Asus rt-n66u with last Asuswrt-Merlin and redirect traffic through the VPN SERVER ( https://hideme.ru/vpn/ ). Settings for OpenVpn Client LINUX, which provides site (ca in_ca.crt, cert in_7481115.crt, key in_7481115.key adjusted via TLS):
client
#connect to VPN server
remote 46.38.63.110 1194
proto udp
#DNS server to use
dhcp-option DNS 8.8.8.8
#remove to use your ISP's gateway
redirect-gateway def1
#your access keys
ca in_ca.crt
cert in_7481115.crt
key in_7481115.key
ns-cert-type server
#use virtual interface 'tap'
dev tap
#keep trying indefinitely to resolve the host name of the OpenVPN server.
resolv-retry infinite
#most clients don't need to bind to a specific local port number.
nobind
#try to preserve some state across restarts
persist-key
persist-tun
#enable compression on the VPN link
comp-lzo
#set log file verbosity.
verb 4
#silence repeating messages
mute 20
#tell the server to immediately close its client instance object rather than waiting for a timeout
explicit-exit-notify
... cool... I did not know such VPN provider even exists! what speeds are you getting on PC client?
Merlin's firmware is relatively easy to setup VPN... you just need to go to VPN page, and select Client.
Are you getting any errors? What does system log say?
