Be forewarned: you will lose all your settings if you flash this beta firmware.
That said it seems to be working fine. I was planning to flash back to .162 today because of issues with .178 but went with the beta instead.
So far so good.
I didn't lose my settings,just sayin
Then you must have already been using 64k-NVRAM enabled firmware or you are flashing from one 32k firmware version to another. If you flashover from 32k to 64K NVRAM firmware you will lose your settings as the NVRAM has to be wiped clean in order for the flash to be successful. You also cannot restore your settings from a backup file as the 32K and 64k firmware versions do not play nicely together. As you were.I didn't lose my settings,just sayin
Is it normal for new firmware to come from the Russian site asus.ru? That's where the link in the OP points.
Thread starter | Title | Forum | Replies | Date |
B | Issue with wired clients on ASUS N56U | ASUS N Routers & Adapters | 0 | |
J | I can't reset or access ASUS TUF-AX6000 GUI | ASUS N Routers & Adapters | 8 |
Welcome To SNBForums
