ASUS RT-N66U - port range forwarding doesn't work?
Renecek
Hello,
using latest merlin on my RT-N66U. I tried to forward port range 51001 - 51250.
On website canyouseeme.org it shows that ports are blocked. Tried 51001, 51002, 51200, 51250 etc.
If I add into asus router single port, like 55555, canyouseeme.org shows me success.
How can I forward port range? Have firewall enabled. See screenshot please.
Thank you
Sorry, must be not awake this morning. Stupid answer deleted...
Sent from my P01M using Tapatalk
For a port forward test to succeed, you need to have software actively listening to the forwarded ports. Since you are forwarding a range, this is unlikely to be the case - those look like ports that get only used on-demand, not that are actively listened to at all time.
RMelin: I need it for rTorrent. Have ports 51001 - 51250 so it's running with random port.
So if rTorrent is currently using port 51009 it will be open right? And canyouseeme will shows other ports as closed right?
Thank you
Thank you
Port 51009 should show as open, provided your client listens to both tcp and udp (udp cannot be easily tested).
Other ports will be shown as either closed or stealth, depending on your computer's own firewall when handling packets sent to these ports.
Just tried it using 380.61 and N66U, port forwarding works. Try your software first, if it fails to port forward, then you can say it's not working.
