CattyWampus
The SmallNetBuilder Reviews and the press on the ASUS RT-N66U advertise Simultaneous Dual Band. I guess it depends on your definition of simultaneous dual band.
The N66U has dual radios to function on 2.4GHz and 5GHz, and that is where the simultaneous stops. You have the choice of setting up an SSID with 2.4GHz, and a second separate SSID with 5GHz. In a matter of speaking there is simultaneous dual band.
I also bought the ASUS USB-N53. Nice USB access, in theory, for 802.11n, but not in reality. The N53 can connect to the N66U 2.4 GHz SSID OR, and notice I wrote the word OR, the N66U 5 GHz SSID, but NOT BOTH.
The N66U DOES NOT use simultaneous Dual Band. And the ASUS USB-N53 does not use simultaneous Dual Band. So I spend a good bit of money for a 802.11a/b/g router and USB card, or for a 802.11n 5GHz router and a 5GHz 802.11n USB card but not both. It is impossible for the N66U and the N53 to use both 2.4GHz and 5GHz at the same time, which is by definition, what 802.11n is all about.
Tomorrow it goes back to ASUS in the original boxes for a refund while I find something that works properly.
