ASUS TUF 4200 and iPhones
vouti
Our household is pulling hairs with our iPhone 15s dropping from the internet very frequently while on Wi-Fi (Wi-Fi connection stays on, but loading content gets interrupted). Any ideas what settings to try? The logs keep repeating the following:
Apr 30 22:16:15 kernel: 7986@C08L1rax0,ap_peer_auth_req_at_idle_action() 773: wcid2 exist in Band0 but Recv Band1, CH36 => SKIP
Apr 30 22:16:15 kernel: 7986@C13L2rax0,MacTableDeleteEntry() 1947: Del Sta:a0:52:XX:XX:XX:c8
Apr 30 22:16:15 kernel: 7986@C13L2rax0,MacTableInsertEntry() 1586: New Sta:a0:52:XX:XX:XX:c8 associated at aid 2 (Number of associated STAs: 4)
Apr 30 22:16:15 kernel: 7986@C08L1rax0,PeerAssocReqCmmSanity() 1501: IE_WLAN_EXTENSION: no handler for extension_id:137
Apr 30 22:16:15 kernel: 7986@C08L3rax0,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - a0:52:XX:XX:XX:c8
Apr 30 22:16:15 kernel: 7986@C08L1rax0,APBuildAssociation() 745: invalid status code(53) !!!
Apr 30 22:16:15 kernel: 7986@C08L3rax0,ap_cmm_peer_assoc_req_action() 2241: ReASSOC Send ReASSOC response (Status=53)...
Apr 30 22:16:15 kernel: 7986@C15L1rax0,WPABuildPairMsg1() 5151: [ERROR] : Not expect calling
Apr 30 22:16:15 kernel: 7986@C08L3rax0,ap_cmm_peer_assoc_req_action() 2241: ReASSOC Send ReASSOC response (Status=0)...
Apr 30 22:16:15 kernel: 7986@C15L1rax0,store_pmkid_cache_in_sec_config() 3866: pStaCfg is null
Apr 30 22:16:15 kernel: 7986@C15L2rax0,PeerPairMsg4Action() 7088: AP SETKEYS DONE(rax0) - AKMMap=WPA3-Personal, PairwiseCipher=AES, GroupCipher=AES, wcid=2 from a0:52:XX:XX:XX:c8
If you're using the latest firmware, version 3.0.0.4.388_33903, this is likely the cause of the connection issues. There have also been multiple reports of similar problems on other MediaTek-based routers running the same firmware version. You can either roll back to the previous version or wait for a fix (if this fix ever happens).
