fruitcornbread
Version 3.0.0.4.388_33965
41.88 MB
2025/10/23
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
ZIP SHA-256 : B4AFCAB4835802411252C05711993D3A1355BB99DE6B8274FEDCE406DDB96A97
FW SHA-256 : 90668bc95d1a5c3130e2c16bc92c3bb551e5c477ce8d3c049daf02bdda73be1f
www.asus.com
41.88 MB
2025/10/23
TUF Gaming AX4200|WiFi Routers|ASUS Global
ASUS gaming routers provide the very best gaming experience, with an arsenal of features and tools designed to improve online gaming performance and give you the competitive edge you need to win.
www.asus.com
