Release ASUS TUF-AX6000 Firmware version 3.0.0.4.388_32432 (2023/08/16)
xander73
Version 3.0.0.4.388_32432
40.11 MB
2023/08/16
Bug Fixes and Enhancements:
1.Added OCN(Open Computer Network) Support .
2.Updated the IPTV settings to ensure improved compatibility with Singtel-Others MIO TV and unifi_biz_voip / KPN services.
3.Resolved the issue where the network service filter was not functioning correctly for IPv6 connections.
4.Addressed the connectivity problem that occurred when clients connected to the guest network of an AiMesh node.
5.Fixed various issues related to v6plus functionality.
6.Addressed GUI bugs that were affecting the search process for AiMesh nodes.
7.Resolved issues related to USB functions for improved performance.
Security Fixes:
1.Allowed binding DDNS to a user's account to reduce the risk of MITM attacks.
2.Fixed CVE-2023-34359,CVE-2023-34358 Unauthenticated Denial of Service.
3.Fixed CVE-2023-34360 Stored XSS.
4.Fixed lighttpd vulnerability, CVE-2023-35720.
5.Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319.
6.Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
7.Fixed openssl vulnerability, CVE-2023-0464.
8.Fixed ReadyMedia vulnerability, CVE-2020-28926.
9.Fixed UPnP vulnerability, CVE-2020-12695.
10.Patched a command injection vulnerability to improve overall security.
11.Strengthened protection against SSH brute force attacks.
12.Fixed the cfg server vulnerability (Repeated in the same list).
13.Fixed the vulnerability in the logmessage function (Repeated without CVE number).
14.Fixed CVE-2022-46871.
15.Fixed Client DOM Stored XSS.
Please unzip the firmware file, and then verify the checksum.
SHA256: c677881cbe983811424e0b43d6a9ad317627697868015d5c54ec1f1520f9f6aa
Any owners of this router here? Since it’s not available in the USA, I haven’t been able to purchase one.
Any feedback about it? My RT-AC86U died and I'm searching for a replacement.
I have no issues.
Have 3 pc....2 laptop.......2 ps5 ......5 Smart TV ....and 1 nas on the 2'5 lan port.......and all work correctly.......
No problems since the last firmware.....
Good and stable router in my opinion
40.11 MB
2023/08/16
Security Fixes:
Hello, I just bought this router model 5 days ago and have updated the latest Firmware,
There is a problem I am facing: speed copy (upload) from my Desktop PC (Windows 10) to the portable hard drive attached to the router's USB port is too slow, only 12 MB/s. At this time, I see that only 1 core of the router working at 25%,
On the contrary, when I copied (download) from the portable hard drive on USB router to my Desktop PC, the speed was very fast, reaching 45 - 48 MB/s and 1 of the 4 cores of the Router worked 100%.
my portable hard drive has very high speed if plugged directly into a PC, over 225 MB/s read and write so the problem is not with portable hard drive
I think the problem lies in the Firmware and will be improved soon in future versions
I use Samba share and connect to the 5GHZ wave, with the same settings, in the tuf ax3000 v1 model, I can achieve speeds of 50 MB/s download and 45 MB/s upload.
I've sent feedback on the router configuration page but haven't received any email replies yet so hopefully I'll find some help here.
I use google translate, sorry for my English not good
hi,
i think is better use a nas for this kind of operations...
a raspberry could be perfect!
i'm using it with openmediavalut and i'm very happy
Not a recommended model.
Reboot it properly: return it for a full refund.
Since that reboot everything has been working fine and no more reboots. Connection appears more stable than with my previous RT-AC86U.
