Release ASUS TUF-AX6000 Firmware version 3.0.0.4.388_33950 (2025/10/01)
fruitcornbread
Version 3.0.0.4.388_33950
43.54 MB
2025/10/01
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum of 10 characters, including at least one letter, one digit, and one special character; disallows consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
ZIP SHA-256 : A1955BF800FF172E412F711B05F8F9DD1C762C88F05C9FBD226D4FCAA12EAFDF
FW SHA-256 : 784660fee898f210c0cd53625eee3f6806e1798a856a9029177c6a05596dddc8
Download: https://dlcdnets.asus.com/pub/ASUS/..._TUF_AX6000_300438833950.zip?model=TUF-AX6000
