fruitcornbread
Version 3.0.0.4.388_33965
43.54 MB
2025/10/23
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
ZIP SHA-256 : D04078A4ECD14C205C3B38490580C7D3BF52BF583A712E3811CF6232214F5455
FW SHA-256 : 8e556c8f4d25399475a737fe34466f0bd9b69c7edec502855783d84bd271e3de
Download: https://dlcdnets.asus.com/pub/ASUS/..._TUF_AX6000_300438833965.zip?model=TUF-AX6000
www.asus.com
43.54 MB
2025/10/23
TUF Gaming AX6000|WiFi Routers|ASUS Global
TUF Gaming AX6000 Dual Band WiFi 6 Gaming Router with dedicated Gaming Port, Dual 2.5G Port, 3steps port forwarding, AiMesh for mesh WiFi, AiProtection Pro network security and AURA RGB lighting.
www.asus.com
