ASUS VivoBook X515EA Intel Core i5-1135G7 64 bit Windows 11 Home Wi-Fi issue
SpasNikolov131
The laptop is connect to internet via usb hub Natec 2.0 dragonfly 3x port usb > ethernet cable connected to router.When is connected to router and Wi-fi is off it shows that laptop is not connected to internet.I have to switch on wi-fi in order to have internet.If i connect ethernet cable straight to hub without going thru router ( deliverer ethernet cable ) i having internet without wi-fi switched on.My question is "Is this a software bug?" or i can fix it somehow and have internet with wi-fi switched off and internet connection comes thru router via LAN cable?
Windows IP Configuration
Host Name . . . . . . . . . . . . : Doom
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Local Area Connection* 1:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 94-E2-3C-80-E9-EB
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 96-E2-3C-80-E9-EA
DHCP Enabled. . . . . . . . . . . : No
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek USB FE Family Controller
Physical Address. . . . . . . . . : 94-0C-6D-A7-D9-E1
Link-local IPv6 Address . . . . . : fe80::d65e:6c71:fad9:b554%6(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.xxx.xxx(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.xxx.xxx
DHCPv6 IAID . . . . . . . . . . . : 402710604
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2E-B6-D9-5D-94-E2-3C-80-E9-EA
DNS Servers . . . . . . . . . . . : 109.104.xxx.xxx
109.104.192.2
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter WiFi:
Description . . . . . . . . . . . : Intel(R) Wireless-AC 9462
Physical Address. . . . . . . . . : 94-E2-3C-80-E9-EA
Link-local IPv6 Address . . . . . : fe80::312d:4252:36d5:bb4a%3(Preferred)
Lease Obtained. . . . . . . . . . : 17 юли 2025 г. 9:24:26
Lease Expires . . . . . . . . . . : 17 юли 2025 г. 15:24:28
DHCP Server . . . . . . . . . . . : 192.168.xxx.xxx
DHCPv6 IAID . . . . . . . . . . . : 60088892
DNS Servers . . . . . . . . . . . : 192.168.xxx.xxx
Change the DNS servers that are configured on your Ethernet interface, use the router's own IP instead just like Wifi does, see if it makes a difference.
I tried to change DNS with router default DNS.Anyway nothing happened , this is what iam getting from router.Ethernet is connected it shows correct socket the connection is stable.So what i think is everything works fine and there is nothing to worry about.
Ethernet
Internet: 100Mbps full duplex
LAN1: Unplugged
LAN2: Unplugged
LAN3: Unplugged
LAN4: 100Mbps full duplex
Focus on the laptop, not the router. If the laptop is able to obtain a DHCP IP lease then it means the network part is working. Next step is to try pinging the router. If you can ping the router but still are not able to browse the web, then this is most likely a DNS issue, seeing how you have a different DNS on your Ethernet versus your Wifi. Did you accidentally configure two static DNS on the laptop's Ethernet interface?
These are manual settings, the thing is when i switch off wi-fi i don't have access to router - it's like my hub don't work.And i think this is my main issue...
And when i run diagnose it says "Can't reach default gateway".And asks to restart the Ethernet network adapter (which in my case is the hub).Just to mention when i tried the hub on normal PC it was working normally.So it must be a laptop issue and iam not sure if it's even a issue or it's just the way it is...In order to having internet which comes from LAN cable from a router you need to have wi-fi on.
