Asus VPN server and Pi-hole
eastavin
Hi. A friend with next to no networking experience has configured his asus-pro ax86u router to use Pihole for ad-blocking, DNS (unbound) and DHCP. I said congratulations. amazing what you can learn at youtube college. As far as I can tell everything works ok when I am using a pc on his LAN. The pi-hole is at 192.168.3.50. This has been assigned on the WAN page for DNS and the DHCP on the router turned off. He now wants to access his router remotely, so he configured wireguard using the default settings and scanned the code with his android smartphone. At this point he finds he can surf the net and log into his router at x.x.3.1. However he is also running a server with proxmox and wants to be able to access the admin page. I can access it from the PC on the lan just fine. The internal address for this is something like proxmox.myurl.online However when he goes there from the web using wireguard he gets a 403. I have never used Pihole or proxmox and so my ability to advise is nonexistent.
I am suspecting the issue might be with the wireguard config that has default to a DNS of 10.6.0.1. Literature I scanned suggests this needs to be set to the pihole at 192.168.3.50. dont know if this is correct advice or not. Exporting the conf file from the router and editing the config for the smartphone results in the same issue 403.
I tried openVPN server with advertise DNS to clients YES. Also no go. Tried NO, no go. Tried setting the DNS on the openVPN client for Android under IP and DNS to 192.168.3.50 and got worse results than wireguard. The browser just freezes.
So either I am missing something basic (very likely) on the router or the client settings or the issue is elsewhere as in Pihole. Can anyone suggest if the wireguard or openVPN needs anything other than the default settings? And does this also depend on a matching setting of somekind in Pihole? If one needs to put the IP address of a wireguard client into Pihole, what would that be looking from Pihole out? 10.6.0.2/32 as in the default config wireguard spits out? One setting giving permission to all wireguard clients would be preferable in my thoughts so we dont have to repeat this. If you think openVPN is easier to make work... good with that too.
Many thanks for any hints.
Ed
