DarkKnight75
Besides tweaks to the software, is it more stable than official Asus firmware?
Thoughts on both?
Thoughts on both?
Thoughts on both?
The answer depends on the complexity/requirements of your installation. For me ASUS firmware had issues with Time Machine function so I moved to Merlin and never looked back. Here are a few basic points about Merlin:Besides tweaks to the software, is it more stable than official Asus firmware?
Thoughts on both?
- Built from ASUS firmware but will lag behind at least by one release level
- Resolves some issues with the ASUS release it’s based on
- Adds some features/function not available in ASUS release
Great..Don't care about aimesh since i don't use it...just want to make sure I can use android app with Merlin firmware.The answer depends on the complexity/requirements of your installation. For me ASUS firmware had issues with Time Machine function so I moved to Merlin and never looked back. Here are a few basic points about Merlin:
- Does not support ASUS AiMesh (Thanks @OzarkEdge)
So what's up with no aimesh support..jeje ?
AiMesh = AiMess
Your least accurate post.
OE
App is a severe security issue!Do you use the ASUS app on Android using Merlin? Just wanna make sure it still connects to the router.
Gracias
Much worse than opening a higher port for SSH.
Many got hacked using it in the past ...
https://www.snbforums.com/threads/p...nt-from-senior-users.45597/page-2#post-392024
https://www.snbforums.com/threads/p...nt-from-senior-users.45597/page-3#post-392078
from Merlin: https://www.snbforums.com/threads/p...nt-from-senior-users.45597/page-3#post-392165
from Merlin: https://www.snbforums.com/threads/p...nt-from-senior-users.45597/page-8#post-403798
from Merlin - read it: https://www.snbforums.com/threads/p...nt-from-senior-users.45597/page-9#post-403858
https://www.snbforums.com/threads/p...nt-from-senior-users.45597/page-4#post-393310
https://www.snbforums.com/threads/a...-activation-of-remote-access-to-router.44181/
https://www.snbforums.com/threads/w...and-password-hacked.36602/page-13#post-379691
https://www.snbforums.com/threads/w...and-password-hacked.36602/page-13#post-470212
please search on your own!
YOU READ all those postings last year and know it very well!
OE: https://www.snbforums.com/threads/p...nt-from-senior-users.45597/page-4#post-393601
OE: https://www.snbforums.com/threads/a...ote-access-to-router.44181/page-2#post-425611
Dont want to search all the other threads for your ease.
And before you will reply with "fixed now" I have to ask for reference posts too.
Either, they are careless with their features and I wont trust them, could easily return with next update like so often with "fixes", even years later!
The app still works in Merlin, I even posted a screenshot on the other thread you created.Got it Do you use the ASUS app on Android using Merlin? Just wanna make sure it still connects to the router.
Gracias
No, not the router itself is a security risc, but we are often told in this forum not to use the app, either because its opening a well known port or the app itself has been vulnerable (I cant say as I never used the app and had not been hacked)!So, yes, those references all appear to relate to the ASUS app enabling remote access to the router in response to the user action to enable remote access. The problem was that the app did not explain and caution the user to consider the consequences... it was too easily and recklessly done by both the app and the user. I think ASUS has since improved the app in this regard... too easy to inadvertently enable remote access, but the app by its administrative nature on a mobile device and OS is still an unnecessary vulnerability to be avoid whether they fixed anything or not, imo. Still, I suspect careful users are using it securely on their LAN by avoiding the remote access feature, hence not a severe security issue for that usage.
The same remote access insecurity can be affected by the user within the router webUI... it's just not so easily and accidentally done there. I don't think you would call the router a severe security issue... at least not the current firmware.
OE
Welcome To SNBForums
