pillykinto
Hi All,
I want to setup Asus Wireguard VPN provider on my Asus router. The network I want is:
- Asus router setup as VPN Server for clients outside the home. i.e 10.6.0.0/32
- No access to internal network i.e. 192.168.1.0/24
- One single internal VPN client hosting adguard home instance running on docker
- All VPN clients will use the internal Adguard docker VPN client for DNS, the adguard docker instance will have interface on both VPN and internal networks to handle all DNS requests from internal/external clients.
- Access Intranet is disabled on VPN server, this is the behaviour I want.
I've tried numerous times to get this to work, by setting the DNS for other clients to the Docker Wireguard client and trying to forward the packets through to adguard running in a separate container.
Anyone have similar setup? I really want to isolate VPN clients to my adguard service only by essentially using the Docker VPN client as reverse proxy for DNS.
