Asus wireguard server
Tulip
Do I need to open the wireguard router port? Did a try but don't seems to work/connect from my android
bbunge
Part of the Furniture
No. Do you have DDNS configured correctly? Is your Asus router behind another router (double NAT)?
Tulip
Thanks for the reply, I have ddns set correctly to my domain. Previous I used wireguard server on my unraid that worked fine, so I removed the portforward to the unraid wireguard server and try to use the router wireguard server instead. No double Nat.
Tulip
Seems like it kinda work now. Another question. Can I set the server to allow both intranet and Internet? Or do I need two profiles?
