Asus WL-330NUL Firmware Revisions
sfx2000
Part of the Furniture
If you have one of these N150 class (N72 class?) travel routers...
FW 3.0.0.37 was released earlier this month - most shipped with 3.0.0.24, so as part of the update path you might want to also do a full reset after the update along with uninstall/reinstall the Windows client SW.
http://www.asus.com/Networking/WL330NUL/overview/ - go to support, drivers and tools for more info
Version 3.0.0.37
Description ASUS WL-330NUL Firmware Version 3.0.0.37
1. Improve the security of WL-330NUL
Version 3.0.0.36
Description ASUS WL-330NUL Firmware Version 3.0.0.36
Fixes:
1. Fix bug : Cannot connect Internet successfully, after changing the wireless environment from PPPoE to others.
2. Fix bug : After upgrading firmware, keep the same PPPoE parameters if user edited it already.
Version 3.0.0.35
Description ASUS WL-330NUL Firmware Version 3.0.0.35
1. Add PPPoE function.
2. Remove access WL-330NUL by www.asusnetwork.net domain name.
3. Fix in Utility-hotspot mode, if parent AP change the authentication from WPA-TKIP to Shared Key, WL-330NUL could not connect to parent AP
4. Fix in short distance WL-330NUL might not receive signal issue.
5. Fix interface can't be activated correctly to complete the utility upgrade.
Version 3.0.0.30
Description ASUS WL-330NUL Firmware Version 3.0.0.30
1. Fixed security issue: avoid DDoS attack
Version 3.0.0.28
Description ASUS WL-330NUL Firmware Version 3.0.0.28
1. Add Japanese language
2. Fixed can't detect ip conflict with Parent AP.
Version 3.0.0.26
Description ASUS WL-330NUL Firmware Version 3.0.0.26
1. Add firmware upgrade function.
2. Speed up the opening time.
3. Add Ethernet wan type for Utility
4. Fix some UI layout bug.
Version 3.0.0.24
Description ASUS WL-330NUL Firmware Version 3.0.0.24
1. Fix when client try to open guest network send request page in Firefox with domain name router.asus.com, the browser could not get the correct information sometimes.
2. Fix Ethernet Adapter mode:change DHCP server will cause process bar abnormal on web page.
3. change the dhcp lease time from 0 second to 1800 seconds, avoid user occupy IP address.
