thegios
Hi, I have just bought two XT8, with following setup:
Question 2: is it ok too connect the desktop to the NODE's WAN port , or should I use a LAN port?
Question 3 (THE MOST IMPORTANT ONE): on the firs day I measured 890 in download for the wired desktop and 650 for the wirelles laptop, but two days after I am measuring 560 for both, and I am a little disappointed since the wired desktop should be faster than the wireless laptop, any idea why?
Thx for the support and let me know if you need additional info to give me support
- - I have FTTH at home, modem provided by ISP, laptop connected via cable on the fibre modem can reach 900 in download
- - I switched off the WiFi on the modem
- - I connected unit 1 /the ROUTER) to the modem via cable from WAN port on the XT8 to a LAN port on the modem
- - Unit 2 (the NODE) is connected to the ROUTER via wireless backbone, connection quality GREAT
- - Single SSID
- - Devices connected:
- Nvidia Shield TV via cable directly to the modem
- Marantz Av Receiver via cable directly to the modem
- Stellite box via cable directly to the modem
- Google Nest Thermostat: this always connects to the ROUTER via wifi 2.4
- Amazon Firestick: this always connects to the ROUTER (EVEN IF IT'S IN ANOTHER ROOM AND IT'S THE FARTHEST DEVICE FROM THE ROUTER) via wifi 2.4 (NOT SURE WHY NOT 5!!!)
- Security webcam: this always connects to the NODE via wifi 5
- Google smart speaker: this always connects to the NODE via wifi 5
- Three smartphone: they connect via wifi 5 on either ROUTER or NODE depending on where they are
- Laptop: this always connects to the NODE via wifi 5
- desktop: this is connected via cable on the WAN port of the NODE
