Hello everyone,
I have an issue that has been driving me bonkers. I have an ASUS Zen XT8 mesh system. I have a bunch of Feit RGB wifi bulbs I'm trying to get working on a 2.4ghz guest network. I can set up the guest network fine, connect all the bulbs, they will all work fine, then 5-10 minutes later the whole guest network crashes and nothing can connect to it, including other devices like my phone and laptop. It seems like an IP/DCHP issue
Details
- I have good wifi coverage, both router and mesh node are in good locations, strong signal everywhere.
- The main wifi network has been working flawlessly the entire time.
- I am aware of the issue with guest network 1, I tried and am having the same trouble on guest network 2.
- Mesh node is connected via ethernet backhaul through an unmanaged network switch.
- AT&T BGW320 Gateway is also plugged into the same switch. It is set up in IP pass-through mode to the ASUS router so the ASUS is handling the local network.
- All wifi radios are turned off in the AT&T gateway.
Any thoughts? Am I doing something wrong or do I just have to hope for a firmware update?
Details
