ASUS ZenWifi AX XT8 - wireless backhaul disconnecting?
bokolobs
Hi! I'm new here. I'm having a problem with a server connected to the main node of a 2-pack. Whenever I'm connected to the satellite node, connection would be lost to that file server. I was wondering if it's the server's fault or the wireless backhaul. What should I look for in the logs to see if at any point the wireless backhaul was broken? Thanks!
P.S.
I have the 3.0.0.4.386_43170 firmware installed.
  • syslog (1).txt
Fall back to previous software 42095. Known bug.
Thank you @kamil666 ! Just reverted back to 42095. Testing right now.
Just to update, I pinged from a client on the mesh node to a server connected to the main router via ethernet. Out of 20,000 packets I lost 2. I don't know if that is acceptable, but it's better than 1.8% packet loss and complete dropout of the mesh node for 5s. At least now, I'm not dropping the connection to that server that has a 3s disconnection limit.
I also reverted back to 42095. I had too many disconnects and dropcam issues.
