Release ASUS ZenWiFi BT6 Firmware version 3.0.0.6.102_58403 (2026/02/24)
fruitcornbread
Version 3.0.0.6.102_58403
63.36 MB
2026/02/24
Improvements:
- Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
- Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
- Refined accessibility-related UI and interaction details.
- Improved overall remote connection stability.
- Improved system behavior when using System diagnostic on feedback page.
- Optimized LED accuracy for AiMesh Ethernet onboarding status.
- Fixed temporary disconnections during client roaming via roam-assist.
Bug Fixes:
- Fixed connection failures when using 5GHz 160MHz bandwidth.
- Fixed an issue preventing 5G WPS from enabling correctly.
- Fixed connectivity issues with NOW TV after configuration.
- Fixed incorrect connection status display for certain Wi-Fi devices.
- Fixed AiMesh nodes not displayed correctly in the device list.
- Fixed a disconnection issue that occurred after enabling the MAC Filter.
- Fixed main network connectivity issue when enabling IPv6 for both the main network and Smart Home Network.
Security Enhancements:
- Enhanced system API validation for stronger protection consistency.
- Strengthened command handling and system resource access controls.
- Improved system logging and security event recording mechanisms.
ZIP SHA-256 : 917204671F50231044DD124FC20079649BEC2B05C98B4CAAFEAEC389A31E52BC
FW SHA-256 : 93EB36CF4F4253F5387D34008A6ACE7A45983B5B3F087AA91C98C266C5A3EAFC
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/BT6/FW_ZenWiFi_BT6_300610258403.zip?model=ZenWiFi BT6
(You will need to copy the link and paste it in a browser for the link above to work.)
