Asus ZenWifi CT8 In AP Mode W/ AC86U Router Question
CorruptedMind
Question... I currently have 1G Fiber with Centurylink, and use the AC86U in Router Mode logging in through PPPOE with a VLAN Tag of 201. I also disabled both wireless radios.
I recently got the ZenWifi CT8 pair and have decided to run them in AP Mode. The AC86U is connected via Ethernet to the main CT8 (AP) and then the second CT8 (Node) is connected via ethernet backhaul to the main CT8 (AP). Ai Mesh appears to be only working with both the Zenwifi CT8's. Couple concerns:
1. Is this a proper setup? Is it true that doing a PPPOE login with a VLAN tag can be more CPU intensive? That's the reason I use the dedicated AC86U to perform the router functions.
2. To get the Ai Mesh to properly work all together, can you make the AC86U in router mode and then add the ZenWifi CT8's as nodes instead of AP Mode? I would like to not use the wireless radios of the AC86U.
3. I've been using Merlins firmware for a long time and love it. I can't remember if he doesn't support Ai Mesh or the new architecture of the Zenwifi?
OzarkEdge
Part of the Furniture
Maybe... each Zen unit is a router so each may also be a node. Try adding them as nodes to the 86U router. However, if you turn OFF the 86U WiFi switch, it will probably upset the AiMesh. But you could try it. I've never tried this as my node is not wired.
OE
