Release Asus ZenWiFi CT8 - New Firmware: 3.0.0.4.386_45934
Frisswinter123
Finally after many donkey’s years, Asus have released a new firmware for ZenWiFi CT8 dated on 17/11/2021.
Change log:
1. AiMesh 2.0
- System optimization: one click in AiMesh to optimize the topology
- System Ethernet backhaul mode, all nodes will only connect by ethernet, all bands will be released for wireless clients.
- System factory default and reboot.
- Client device reconnect, make the device to offline and online again.
- Client device binding to specific AP.
- Guest WiFi on all Mesh nodes (all node need to upgrade to 3.0.0.4.386 firmware)
- Access nodes USB application
Source: https://www.asus.com/sg/Networking-...Fi-WiFi-Systems/ZenWiFi-AC-CT8/HelpDesk_BIOS/
aphoons
Change log:
1. AiMesh 2.0
It broke my ct8 as nodes. Hahaha. Had to revert back to previous firmware
Frisswinter123
Already using the latest firmware, no such issue at all. A stable and good update after so long!
Finally got Tri-band Wireless option with 1 single wireless SSID (2.4, 5-1 and 5-2GHz) when enable Ethernet backhaul option. It have the option to enable DNS over TLS.
After login to the router via web portal, what I do is not using the check for update button, I download the firmware from Asus website then update my Node 2 by manual uploading the firmware, once finish then I off and on the power and let it re-establish the connection with my main node.
After node 2 is up, i manually update my main mode to latest firmware, then once it updated and detect my node 2, I off and on the power to main node let it auto re-connect back to my node 2.
lastly, I power off and on ONT (fibre box) that connected to my main node, and everything is good and do a Speedtest. That all.
Smokey613
I got a pair of CT8 off eBay recently to replace my eero pro units. I installed latest firmware, reset the units twice to be sure I was working from a clean slate. I got them setup and working with wifi backhaul. The web gui seemed a little “glitchy” but thought it was just the nature of the CT8 platform.
Over the past week, I never got the wifi performance I was expecting. Even though the backhaul showed a great connection in the wireless log, I could never get more than about 50m when running speedtest from my two computers plugged into the node unit.
I tried several adjustments and eventually did another reset, left everything default except ssid/password pn the 2.4 and 5-1 bands. The system still seemed flaky and sluggish when navigating the web gui.
Today, I did another reset, installed 3.0.0.4.386.23003, set my ssid/passwords and just let ut run. Wow! Now my setup performs as expected. I can now get 98m of my 100/10 speed on both computers and the web interface is quick and smooth. For now, I am staying with this firmware.
I will be converting them to AP mode later this week and place them behind an Untangle unit I am building so not too worried about security updates.
