ASUS ZenWiFi Pro ET12|Whole Home Mesh WiFi System|ASUS Global
Mesh wifi 6e system for whole home signal coverage, Broadcom, 6GHz, 2.5G ports, network security, parental controls, easy setup and manage. PS5 compatible, supports QoS and app control
New Features:
-Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
-DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
Bug fixes and functionality modifications:
-Resolved the issue with login and password changes.
-Resolved the IPSec VPN connection issues.
-Resolved the Instant Guard connection issues.
-Fixed the issue where Traffic Analyzer sometimes couldn't record data.
-Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
-Fine-tuned the description for port status.
-Enabled DynDNS and No-IP DDNS to use IPv6.
-Fixed AiMesh preferred AP identification in site survey results.
-Updated timezone list for Greenland, Mexico, and Iran.
-Fixed memory leak issue.
Security updates:
-Enabled and supported ECDSA certificates for Let's Encrypt.
-Enhanced protection for credentials.
-Enhanced protection for OTA firmware updates.
-Fixed DoS vulnerabilities in firewall configuration pages. Thanks to Jinghe Gao's contribution.
-Fixed DoS vulerabilities in httpd. Thanks to Howard McGreehan.
-Fixed information disclosure vulnerability. Thanks to Junxu (Hillstone Network Security Research Institute) contribution.
-Fixed CVE-2023-28702 and CVE-2023-28703. Thanks to Xingyu Xu(@tmotfl) contribution.
-Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group - cse hkust contribution.
