Release ASUS ZenWIFI Pro XT12 Firmware version 3.0.0.6.102_36697 (2026/03/12)
fruitcornbread
Version 3.0.0.6.102_36697
51.12 MB
2026/03/12
Improvements:
Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
Refined accessibility-related UI and interaction details.
Improved overall remote connection stability.
Improved system behavior when using System diagnostic on feedback page.
Bug Fixes:
Fixed incorrect connection status display for certain Wi-Fi devices.
Fixed AiMesh nodes not displayed correctly in the device list.
Fixed a disconnection issue that occurred after enabling the MAC Filter.
Security Enhancements:
Strengthened input sanitization mechanism.
Enhanced system API validation for stronger protection consistency.
Strengthened command handling and system resource access controls.
Improved system logging and security event recording mechanisms.
ZIP SHA-256 : EB5F8059CE3C5BEF1E59C28B55393E31B165B4B0CE5D14900AC76320F2F308D9
FW SHA-256 : 3DD4137D42606E0FB056506FFB1B5CF698FA835087735AF143D9A14DAFBA01CE
Download: https://dlcdnets.asus.com/pub/ASUS/..._XT12_300610236697.zip?model=ZenWIFI Pro XT12
(You will need to copy the link and paste it in a browser for the link above to work.)
