Release ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388.21963
dearjvi
Version 3.0.0.4.388.21963 48.11 MB
1. Fixed IPTV compatibility issue with Movistar. Thanks to Sergio de Luz from RedesZone.net.
2. Fixed VPN fusion, AiMesh, and Network map GUI bugs.
3. Fixed WAN compatibility issue with Starlink router.
4. Fixed miniupnpc vulnerabilities, CVE-2015-603, CVE-2017-1000494
5. Fixed IPSec server vulnerability, CVE-2022-40617
6. Improved connection speed with Verizon FIOS.
Please unzip the firmware file first then check the MD5 code.
MD5: eea8f89d716302b89b857211e3725158
I hope this will resolve the issues I had with the previous version, i have the new version running stable for around 15 hours.
I will provide an update again in around 7-8 days with the previous version my issues started around 7-8 days uptime.
How have you found this latest firmware?
I have problems using the XT9 on the latest firmware as mesh edge via 2.5 Gbps LAN port. Wireless backhaul works fine. Not sure related to this firmware or a previously existing issue.
OK so with the latest firmware 3.0.0.4.388_22068 this issue seems resolved and I'm able to run the XT9 as a wired mesh node just fine.
