Release ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24710 (2025/04/22)
fruitcornbread
Version 3.0.0.4.388_24710
50.28 MB
2025/04/22
Improved compatibility with certain IoT devices.
ZIP SHA-256 : 0FFEA1FBFE4F19E34FADDB147FD26856A298E37B6B22DEDCA1251BC22FC9C7F6
FW SHA-256 : 352169e9f5ec018d0c8d470dd535c3e140af1c5bbe072bb520b0f9cd0327fde0
Download: https://dlcdnets.asus.com/pub/ASUS/...ENWIFI_XT9_300438824710.zip?model=ZenWiFi XT9
Anyine tried this update yet? Interested to know if devices can connect to the nodes as the last update kind of screwed that up
Upgraded all nodes and my router in my mixed XT9/XT8 system and still getting the "kernel: Can't add zero mac!" error in the system log. Still appears after resetting my system and starting from scratch again. Seems to happen with AiMesh nodes connected via WiFi. I'm just going to charge through it and see if it stays stable or not. Otherwise, I'm downgrading and restoring my old configuration.
I update my XT12 to 3.0.0.6.102_35213 and then my two XT8 with 3.0.0.4.388_24710 and the XT8 did not want to connect to the router.
Then I tried to make a factory reset on the XT8 and added them again to the XT12 AI Mesch and now the system works fine again.
It has been up for about 1 day now and streaming video and other Internet access is working fine also my IOT devices does work.
I just wanted to update that my network seems to be stable now after I factory reset the router, all nodes, and set everything back up again from scratch. I had the "Can't add zero mac!" error for a day or two afterwards but it has since disappeared. No issues with devices so far so lets see how long this lasts.
Upgraded my Zen ATX mesh router and mesh nodes to 24710. One of them got stuck in setup mode (solid blue led) for some reason, even though it seemed to be working but, would eventually shutdown (I suspect because it was kind-of in setup mode). Removed it from the mesh, effectively factory resetting it, re-added it, and it is fine. Seems like a factory reset is almost always the solution, even better then down-grading sometimes.
