so how 'bout an informal critique?
Glad you asked!
Build Quality:
Metal enclosure, nice clickyness when you insert the drives, seems pretty quiet, although I have nothing to compare it to.
Setup:
The Asustor 5002T arrived on my doorstep last night after work. By 9pm I had configured to my liking and integrated and into my network, SAB,Couchpotato, FTP, NFS, SAMBA, SSH, permissions, Plex, UPNP etc. So it was super easy to setup and get configured. I used a single WD RED 6TB drive and upgraded to 4GB ddr3 ram, some old macbook memory a friend gave me, it worked perfectly. I setup link aggregation as well (Adaptive Load Balancing) really cool feature, I'm not positive it increased throughput and stability because I started with LAG from jump but I suspect it's been helpful.
Performance:
I was really concerned about SABNZBD performance and Plex transcoding however my concerns were quickly alleviated when I was able to achieve full download speeds thru SAB (10mb per sec) after just a few tweaks to the configuration. Transfer speeds from my desktop backed up folders (totaling about 75GB in movie directories) moved very swiftly topping out at about 107mb per second. While that was transferring I decided to push the little box as far as I could so while the transfer was happening I downloaded some very large files through SABNZBD and began Plex streaming to my phones and laptops (2 local network, 2 outside network) and streamed a 1080p film through NFS to my living room TV. It all went off without a hitch for the most part, however fast forwarding/skipping while all this was happening did cause some issues and my file transfers fell to about 80mb per sec. The CPUs were absolutely pinned at 100% during this process which is to be expected. Overall I was pretty impressed
Plex transcoding definitely taxes the CPUs which do not yet take advantage of the Intel Quick Sync feature of the j1800 Baytrail processor. I touched base with ASUSTOR about this and they confirmed they will be incorporating the FFMPEG-QS fork to improve transcoding by Q2 of this year (whether or not this applies to Plex or just their aiVideo app I have not been able to confirm yet).
I have not yet been able to test the consistency of multiple streams over a long period of time since I was just kinda messing around, however I should find out soon enough. Lots of my friends and family use my Plex server to stream stuff to their smart tvs/apple tvs/phones etc. On my old NAS (ix2-dl) I was running all my apps on my desktop and just using the NAS as storage and this caused a ton of issues with streams failing, stalling out local streams etc. Hopefully I can finally turn off my main PC and save some power by running everything on this powerful little bastard. PS do not waste money on the ix2-dl it is garbage.
Pros:
-Super powerful
-LAG really seems to help with multiple streams load balancing and such
- App store is robust,tons of apps
- Accepted off the shelf memory (DDR3)
- Easy to setup
- Fairly quiet
Cons:
My biggest issue thus far is with flaky access to the server while outside the network, for some reason I'm having trouble connecting to the thing from my phone and browser at work. Sometimes it works perfectly other times I get 404 errors, sometimes I get kicked off the server and when I try to reconnect it just stalls. I put in a trouble ticket with ASUSTOR
- No Quick Sync support yet
- Asustor forums are basically a ghost town, not nearly as much community support as Synology, QNAP etc
- The Android Apps aren't well designed and there are problems connecting to the various services.
- The CPU seems to run really hot its been at 50c or higher all day
Overall:
I'm really pleased with this NAS so far. There are a few nagging issues however I'm fairly confident they will be resolved. For $308 from Amazon this thing is a steal. Time will tell whether or not it can handle the stress I plan on putting it through but so far so good. I'm really excited to find out where it stacks up against other 2 disk NAS servers in its class...
I was going to build a stand alone NAS mini-itx server if this didn't work out but it seems like I won't have to go that route. I think I'm happier with just buying an off the shelf device because of how easy it is to get everything up and running. I know FreeNAS is solid but I would imagine getting LAG working properly and getting all my apps and services working up to snuff would have been a big pain in the butt.
