Asuswrt-Merlin - Port Forwarding Settings
Bake
I was having an issue with my settings for Port Forwarding on an RT-AC86U using the latest Asuswrt-Merlin firmware 386.2_4.
When I add the necessary settings they simply vanish once I signoff. The only way I have found that the Port Forwarding settings will be kept is adding 0.0.0.0 in the Source IP box.
Once I do that all of the settings are saved.
The Source IP is supposed to be "Optional" but unless I add the 0.0.0.0 into the Source IP nothing is saved?
I tried a number of previous Merlin firmware versions all with the same result.
I am wondering if I am missing something on this page?
Any thoughts from those with more experience in Port Forwarding would be great!
That's odd. Same firmware and router here, and I have 6 port forwarding entries, all of which have source IP blank, and have never had a problem. I've never seen what you describe on any firmware version with the 86u. There aren't any tricks to the page, no - just "add profile", enter the settings, and "OK" should preserve them, e.g.
Thanks JacquesR for responding. In my case this ASUS 86u is a brand new ASUS router I got to act as my backup router which I decided to use as the permanent one, the other is on my shelf. I think that they are both the same 9maybe not). To make this more interesting I also found one source link below that actually instructs that 0.0.0.0 should be added as the Source IP unless of course you have a specific Source IP that you are using.
The Link: https://openmyip.com/asus-rt-ac86u-router-setup
If you have a chance try adding 0.0.0.0 as a Source IP on one of your Port Forward sets and see if it causes any issues.
Let me know what you find.
Link;
It makes no difference, as I'd expect. 0.0.0.0 is (in this case) the same as "any address". Your problem - at least as you initially articulated it - wouldn't be affected by my trying 0.0.0.0 instead of leaving it blank, though, as that would tell you nothing about why your settings aren't being saved.
But to conclude my contribution (as a complete non-expert): a) why not just enter the 0.0.0.0 rather than leaving it blank, if that results in a successful save of settings; and b) if the instructions in the link you sent were important, you'd have found them here or in the Asus-Merlin documentation.
I had the same problem with my RT-AX88U. I decided to try to script the changes I wanted to keep in the hope that they would persist during reboots. Mine was only disappearing after reboots. I connected with a terminal to check whether my jffs partition was writeable or not. After doing a "touch file" command I received a response of no space on disk. I decided to reformat the jffs partiton in the hope that would alleviate the problem. After I rebooted, "touch file" resulted in a new file and all my lost settings were available again! I deleted the new file and now everything seems to be working ok again. I would suggest maybe you try reformatting your jffs on the next reboot.
