Atom boards with more than 2 Sata ports
bdresch
I'm planning to build a DIY NAS. The reason I want to do DIY is because I have everything I need but a motherboard. I am only going to use 2 3tb drives to start with but want some expansion capability. Are there any atom boards with more than 2 Sata ports under $100? I've seen the supermicro ones with 6x but they are a bit more than I'd like to spend.
I found a few Atom boards with more than 2 SATA ports. I'll just post links to the store I found them on as they should be available at other online retailers as well.
http://ncix.com/products/?sku=69601&vpn=AT5NM10T%2DI&manufacture=ASUS
- 4 SATA ports
http://ncix.com/products/?sku=77958&vpn=IONITX%2DE%2DE&manufacture=Zotac
- 4 SATA ports
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813500055
- 6 SATA ports
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813153212
- 6 SATA ports
