AU86U - Merlin 386.1 - System Log errors
HotWheels
I updated my 86U to Merlin 386.1 a few days ago and everything seems to be working fine. I was checking logs and notice this repeating block of errors (log level is set to critical): Any input ?
Feb 8 15:20:08 kernel: protocol 0800 is buggy, dev eth5
Feb 8 15:20:12 kernel: protocol 86dd is buggy, dev eth5
Feb 8 15:20:16 kernel: protocol 86dd is buggy, dev eth5
Feb 8 15:20:17 kernel: protocol 86dd is buggy, dev eth5
Feb 8 15:20:18 kernel: protocol 0800 is buggy, dev eth5
Feb 8 15:20:19 kernel: protocol 86dd is buggy, dev eth5
Feb 8 15:20:28 kernel: protocol 0800 is buggy, dev eth5
Feb 8 15:20:38 kernel: protocol 0800 is buggy, dev eth5
Feb 8 15:20:42 kernel: protocol 0800 is buggy, dev eth5
Feb 8 15:20:47 kernel: protocol 86dd is buggy, dev eth5
Feb 8 15:20:48 kernel: protocol 0800 is buggy, dev eth5
Feb 8 15:20:51 kernel: jffs2: Argh. No free space left for GC. nr_erasing_blocks is 0. nr_free_blocks is 0. (erasableempty: yes, erasingempty: yes, erasependingempty: yes)
Feb 8 15:20:51 kernel: jffs2: jffs2_reserve_space_gc of 196 bytes for garbage_collect_dnode failed: -28
Feb 8 15:20:51 kernel: jffs2: Error garbage collecting node at 02600000!
Feb 8 15:20:53 kernel: protocol 86dd is buggy, dev eth5
Feb 8 15:20:54 kernel: protocol 86dd is buggy, dev eth5
Feb 8 15:20:54 kernel: jffs2: Argh. No free space left for GC. nr_erasing_blocks is 0. nr_free_blocks is 0. (erasableempty: yes, erasingempty: yes, erasependingempty: yes)
Feb 8 15:20:54 kernel: jffs2: jffs2_reserve_space_gc of 196 bytes for garbage_collect_dnode failed: -28
Feb 8 15:20:54 kernel: jffs2: Error garbage collecting node at 02600000!
Feb 8 15:20:55 kernel: protocol 86dd is buggy, dev eth5
Feb 8 15:20:59 kernel: jffs2: Argh. No free space left for GC. nr_erasing_blocks is 0. nr_free_blocks is 0. (erasableempty: yes, erasingempty: yes, erasependingempty: yes)
Feb 8 15:20:59 kernel: jffs2: jffs2_reserve_space_gc of 196 bytes for garbage_collect_dnode failed: -28
Feb 8 15:20:59 kernel: jffs2: Error garbage collecting node at 02600000!
Treadler
Shift your guest network/s from position 1, to position 2.
i.e shift them to the right on the guest network page.
Will fix ‘some’ of your error messages.
HotWheels
Moving in over seemed to get rid of some of the error, that is rather strage. I just went ahead and did a hard reset and it has been a long time and several fw updates.
eibgrad
There are numerous known issues w/ Guest #1. IMO, it's just best for everyone to avoid it until the next release.
