TikingAlien007
How do you if you have enabled Auto Firmware Updates manage it ? My understanding is that when Auto Firmware Updates are turned on, it will automatically patch the router which is fine and good for security but my concern is when this happens, does the Asus router keep the settings that were set up in the older firmware or do you go over the settings to double check them each time the update happens ?
I saw on different routers that when Auto Firmware Updates are enabled and new features are rolled out they will be automatically enabled by default, not sure how it is with Asus routers ? I think my main concern would be that Auto Firmware Updates that are coming from the official Asus repository would change some of my router's settings or more so the ones that are responsible for security like external access to the router etc that would end up exposing it to the internet more without my knowledge.
Any advice is appreciated.
