AutoBW: Automatically set QoS bandwidth using spdMerlin
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
squidbilly
AutoBW
Automatically set QoS BandWidth
Last Updated on 4/5/2020 to v1.5
Set QoS upload/download bandwidth using spdMerlin (via Ookla speedtests)
Requires bc and spdMerlin (v3.3.2 or greater)
Execute the following command to download:
curl "https://raw.githubusercontent.com/squidbillyms/AutoBW/master/AutoBW" -o /jffs/scripts/AutoBW && chmod 755 AutoBW
v1.0 (3/25/2020): Initial Release
v1.1 (4/01/2020): Complete rewrite
-No longer requires bash
-Checks that bc is installed & QoS enabled & upload traffic is directed to unthrottled class
-No need to stop/start QoS
-Class rates/ceils are scaled
v1.2 (4/03/2020): More changes
-Check for spdMerlin
-Formatted logger message concerning new BW
-Check for appropriate iptable rules that ensure spdMerlin traffic in unaffected by QoS
v1.3 (4/03/2020): Changed an important check
-Check for spdMerlin v3.3.2 or greater to ensure that QoS will not interfere with calculated speeds
v1.4 (4/03/2020): Added option for automatic updates (Thanks maghuro)
-If turned on, check for updates. If found then update.
-AutoUpdate is off by default and must be turned on
-TestMode is on by default and must be turned off
-Fixed scenario where previous bandwidths were zero. In this case, just set the scale factors to 1 since we cannot divide by zero
v1.5 (4/05/2020): Now handles VPN and Gbps|Mbps|Kbps rates/ceils
-Use VPN values, if defined (thanks maghuro)
-Handle rate/ceil units other than just Kbps (thanks peepsnet)
Thanks to:
FreshJR: Some of the functionality was either taken directly or adapted from the excellent work found in the Adaptive QoS script.
Jack Yaz: For spdMerlin and other input.
Merlin
Creating this small, minor script has shown me just how much time and effort must be devoted to the larger projects that I routinely use.
Kingp1n
AutoBW
Last Updated on 4/03/2020 to v1.2
Execute the following command to download (chmod 755 AutoBW if necessary):
Thanks to:
Merlin
Creating this minor small script has shown me just how much time and effort must be devoted to the larger projects that I routinely use.
This is awesome work....will def try it out. Thanks for this cool and nifty script !!!
immi803
@squidbilly
I always stayed with amtm available options and transmission from entware external options
This project looks promising as always felt qos bandwidth limits should be auto set
Huge thanks
Can someone share "bc" needed in addition to spdmerlin, so i try this out
"bc" entware install command or "bc" github link , appreciate
Gatsu
@immi803 installing bc when u have entware it is as simple as:
opkg install bc
squidbilly
Just updated so that AutoBW will now check to make sure you have spdMerlin v3.3.2 or greater. This will ensure calculated speeds are not influenced (and are thus rendered inaccurate) by QoS.
immi803
See "no such file or directory"
ASUSWRT-Merlin RT-AC88U 384.16_beta3 Tue Mar 31 15:42:15 UTC 2020
[email protected]:/tmp/home/root# curl "https://raw.githubusercontent.com/squidbillyms/AutoBW/master/AutoBW" -o /jffs/scripts/AutoBW && chmod 755 AutoBW
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 100 12551 100 12551 0 0 19132 0 --:--:-- --:--:-- --:--:-- 31299
chmod: AutoBW: No such file or directory
maghuro
Try
curl "https://raw.githubusercontent.com/squidbillyms/AutoBW/master/AutoBW" -o /jffs/scripts/AutoBW && chmod 755 /jffs/scripts/AutoBW && sh /jffs/scripts/AutoBW
immi803
Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 12551 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 100 12551 100 12551 0 0 15927 0 --:--:-- --:--:-- --:--:-- 17904
[email protected]:/tmp/home/root# curl "https://raw.githubusercontent.com/squidbillyms/AutoBW/master/AutoBW" -o /jffs/scripts/AutoBW && chmod 755 /jffs/scripts/AutoBW && sh /jffs/scripts/AutoBW
Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 100 12551 100 12551 0 0 14426 0 --:--:-- --:--:-- --:--:-- 21865
TEST MODE: No changes will be made.
----------- SPDMERLIN --------
Download (Kbps) Upload (Kbps)
Test 1 of 1 40212.5 41482.2
Scale Factors 0.85 0.85
Scaled Speeds 34180.6 35259.9
------------- QOS ------------
Previous 0.0 0.0
New (from above) 34180.6 35259.9
Runtime error (func=(main), adr=30): Divide by zero
Scaling by 0.000 0.000
============================ DOWNLOAD =============================
------------- RATE ----------- ------------- CEIL -----------
Class Previous (Kbps) New (Kbps) Previous (Kbps) New (Kbps)
(standard_in) 1: illegal character: M
(standard_in) 1: syntax error
11 printf: invalid number '1895Mbit'
0.0 printf: invalid number 'ceil'
0.0 printf: invalid number '1895Mbit'
0.0 printf: invalid number 'burst'
0.0
printf: invalid number '1249348b'
0 printf: invalid number 'cburst'
0.0 printf: invalid number '1249348b'
0.0 0.0 0.0
(standard_in) 2: syntax error
10 524288.0 printf: invalid number '1895Mbit'
0.0 printf: invalid number '654311b'
0.0
0.0 0.0 0.0 0.0
13 524288.0 printf: invalid number '1895Mbit'
0.0
0.0 0.0 0.0 0.0
12 printf: invalid number '1048Mbit'
0.0
printf: invalid number '1249378b'
0.0 0.0 0.0
15 314568.0 printf: invalid number '1895Mbit'
0.0 printf: invalid number '391951b'
0.0
0.0 0.0 0.0 0.0
14 419424.0 printf: invalid number '1895Mbit'
0.0 printf: invalid number '523126b'
0.0
0.0 0.0 0.0 0.0
17 104856.0 printf: invalid number '1895Mbit'
0.0 printf: invalid number '129575b'
0.0
0.0 0.0 0.0 0.0
16 209712.0 printf: invalid number '1895Mbit'
0.0 printf: invalid number '260750b'
0.0
0.0 0.0 0.0 0.0
============================= UPLOAD =============================
0.0
0.0 0.0 0.0
0.0
0.0 0.0 0.0 0.0
0.0
0.0 0.0 0.0 0.0
0.0
0.0 0.0 0.0
0.0
0.0 0.0 0.0 0.0
0.0
0.0 0.0 0.0 0.0
0.0
0.0 0.0 0.0 0.0
0.0
0.0 0.0 0.0 0.0
immi803
Previous               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
Not applying :(
maghuro
Previous               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
    0.0
    0.0             0.0               0.0             0.0
Not applying :(
Thanks!
Just pulled request to author to correct this issue
Kingp1n
Thanks!
Wait...should I wait for an update prior to installing current release version?
maghuro
@Jack Yaz and @squidbilly just my 2 cents - why don't you guys work together and implement this great ideia inside your spdMerlin script?
As this script is totally dependent of your spmerlin, you can work together and implement it. Mantained mostly by squidbilly, but together.
What do you think?
visortgw
It has been updated to v1.4 which addresses the issue maghuro posted about earlier.
Quick question: why are upload speeds limited to 100 Mbps? I have 400/20 connection...
Test  1 of  2      459950.1         23705.6
Test  2 of  2      346695.7         23408.6
Average            403322.9         23557.1
Scaled Speeds      342824.4         20023.6
* Download speed (342824.4 Kbps) > upper limit (102400.0 Kbps)
Corrected Speeds   102400.0         20023.6
immi803
@maghuro @squidbilly
Noticed you set auto configuration to 85% of total bandwidth, can we have option to set at 90% or something whatever available total bandwidth recorded by spdmerlin ? I hope such option will help alot
squidbilly
Sure, just change it in the top (configuration part) of the AutoBW script to whatever works for you.
#Scale average values by this factor
# Adjust to optimize bufferbloat and quality grade at DSLreports.com
down_scale_factor=0.85
up_scale_factor=0.85
maghuro
You can manually change for everything you want
