Turgut Kalfaoglu
This is the script I wrote to automatically throttle transmission based on the ping values to our uplink..
It features fast download throttling against impulse usage, and pause before re-increasing the download speed if it was recently lowered.
Feel free to use it, but you will need ooRexx installed.
#!/opt/bin/rexx
/* Automatic Transmission throttle based on the ping values from your next hop.
By Turgut Kalfaoglu <turgut@kalfaoglu.com>
Usage: start this script with the quiet option for regular use. quiet option prevents output to screen.
For example: in /jfss/bin/services-start :
/usr/bin/nohup /opt/bin/transmission-throttle quiet &
may be used to start it
Requires OOrexx
Outputs to /opt/var/log/transmission-throttle.log
parse arg quiet
if quiet='quiet' then quiet=1
else quiet=0
login = 'root:itspassword' /* transmission RPC login infomation - set it in transmission config */
speed=900 /* initial speed in bps */
minspeed=10 /* minimum bps possible */
maxspeed=1500 /* maximum bps you want transmission to use */
threshold = 70 /* in ms - we try to keep pings below this value */
steps = 50 /* lower/increase speed by "steps" bps */
targetip = "71.16.10.1" /* The IP of your uplink - at telecom. do a traceroute www.kalfaoglu.net to find out your next hop */
"/opt/bin/transmission-remote --auth" login "-d " minspeed ">/dev/null"
'/opt/bin/rxqueue /clear'
lastlowered=time('R')
lastlowered=time('E')
do forever
setspeed=0
"ping -W 5 -c 3" targetip "| grep round | /opt/bin/rxqueue"
if queued()>0 then do
oldspeed=speed
parse pull "min/avg/max =" .'/'line'/'.
if quiet=0 then say 'avg ping:' line 'ms'
if line>threshold*2 then do /* is the line VERY busy? decrease it a lot */
speed=speed-(steps*2)
if speed<minspeed then
speed=minspeed
else
if quiet=0 then say 'speed lowered by' steps*2
end
if line>threshold then do
speed=speed-steps
speed=minspeed
else
end
if line<threshold then do
if time('E')-lastlowered>30 Then do
speed=speed+steps
if speed>maxspeed then
speed=maxspeed
else
if quiet=0 then say 'speed raise by' steps
end
else /* will not raise right after lowering it.. */
if quiet=0 then say 'cannot raise speed yet' trunc(time('E')-lastlowered) 'secs elapsed'
end
if oldspeed<>speed then do
if quiet=0 then say 'speed changed.. setting transmission to ' speed
'/opt/bin/transmission-remote --auth' login '-d' speed '>/dev/null'
'echo' date() time() 'ping' line 'current speed' speed '>> /opt/var/log/transmission-throttle.log'
end
end
'sleep 5s'
end
