Tutorial Automatically update qbittorrent connection port on ubuntu with ProtonVPN port forwarding via Wireguard on Merlin
el_pedr0
Automating ProtonVPN Port Forwarding with qBittorrent (WireGuard + Asuswrt-Merlin)​
🎯 Objective​
This guide explains how to automatically update qBittorrent’s listening port with the current port forwarded by ProtonVPN when using WireGuard on Asuswrt-Merlin.
Why? ProtonVPN rotates your forwarded port regularly when NAT-PMP is enabled. If qBittorrent isn’t updated, you’ll might lose incoming connections.
We’ll:
  • Run ProtonVPN WireGuard on an Asuswrt-Merlin router
  • Run qBittorrent on an Ubuntu host (could be bare metal, LXC, VM, etc.)
  • Use a Bash script + systemd service to keep qBittorrent’s port in sync with ProtonVPN
  • Store credentials safely and keep logs clean
This setup is hands-off once deployed.
Caution
I tested with UDP, I haven't confirmed if it works with TCP.
âś… Prerequisites​
  • ProtonVPN Plus or Unlimited subscription (port forwarding requires it)
  • Asus router running Asuswrt-Merlin firmware with WireGuard client configured
  • ProtonVPN WireGuard profile set to:
  • Ubuntu (or Debian-based) host running qbittorrent-nox or qBittorrent desktop
  • A user called qbittorrent which will run and own the script (alter the relevant steps below if you use a different username)
  • natpmpc installed on the Ubuntu host:
    • Code:
      sudo apt update && sudo apt install natpmpc curl
  • Access to qBittorrent’s WebUI (e.g. http://127.0.0.1:8080)
⚙️ Step 1 – Test NAT-PMP with ProtonVPN​
On your torrent host, run:
natpmpc -a 1 0 tcp 60 -g 10.2.0.1
  • 10.2.0.1 is the default ProtonVPN WireGuard gateway (check your WG config if different).
  • Output should include a mapped TCP port.
If this works, you’re good to automate.
⚙️ Step 2 – Config File​
Create a config file at /etc/qbportupdater.conf:
# qBittorrent updater config
QBIT_USER='admin'
QBIT_PASS='yourpassword'
QBIT_HOST='127.0.0.1:8080'
GATEWAY='10.2.0.1'
Notes:
  • Wrap the password in single quotes to avoid issues with special characters (!, #, %).
  • Keep this file owned by qbittorrent user and permissions 600:
    • Code:
      sudo chown qbittorrent:qbittorrent /etc/qbportupdater.conf
      sudo chmod 600 /etc/qbportupdater.conf
⚙️ Step 3 – The Script - part 1​
Save this to /usr/local/bin/qbportupdater.sh:
##NB: The forum prevented me from pasting the correct curl commands in the script below. Note that you should include the -s flag immediately after curl
#!/bin/bash
qbportupdater.sh
Continuously updates qBittorrent’s listening port to match the
ProtonVPN-assigned NAT-PMP port when using WireGuard.
Requires:
- natpmpc
- qBittorrent WebUI enabled
- /etc/qbportupdater.conf with credentials and gateway
set -euo pipefail
set +H
CONF_FILE="/etc/qbportupdater.conf"
STATE_FILE="/tmp/qb_current_port"
# Load config
if [[ ! -f "$CONF_FILE" ]]; then
  echo "Config file not found: $CONF_FILE"
  exit 1
fi
source "$CONF_FILE"
while true; do
  TIMESTAMP=$(date '+%Y-%m-%d %H:%M:%S')
  # Request NAT-PMP TCP port from ProtonVPN gateway
  OUT=$(natpmpc -a 1 0 tcp 60 -g "$GATEWAY" 2>/dev/null || true)
  PORT=$(echo "$OUT" | grep "Mapped public port" | awk '{print $4}' || true)
  if [[ -z "$PORT" ]]; then
    echo "[$TIMESTAMP] ERROR: Could not obtain port"
    sleep 60
    continue
  fi
  # Check previous port
  PREV_PORT=$(cat "$STATE_FILE" 2>/dev/null || echo "none")
  if [[ "$PORT" == "$PREV_PORT" ]]; then
    # Quiet log – only report when it changes
    sleep 45
    continue
  fi
  echo "[$TIMESTAMP] Port changed to $PORT, updating qBittorrent"
  # Log in and update qBittorrent
  COOKIE_JAR=$(mktemp)
  trap 'rm -f "$COOKIE_JAR"' EXIT
 #NB INSERT -s after the word curl below - this forum does not allow me to paste the line with the -s flag!
  curl --cookie-jar "$COOKIE_JAR" \
    --data "username=${QBIT_USER}&password=${QBIT_PASS}" \
    "http://${QBIT_HOST}/api/v2/auth/login" >/dev/null
  curl --cookie "$COOKIE_JAR" \
    --data "json={\"listen_port\":${PORT}}" \
    "http://${QBIT_HOST}/api/v2/app/setPreferences" >/dev/null
  echo "$PORT" > "$STATE_FILE"
  echo "[$TIMESTAMP] qBittorrent listen port updated successfully"
  sleep 45
done
Make it executable:
sudo chmod 755 /usr/local/bin/qbportupdater.sh
sudo chown qbittorrent:qbittorrent /usr/local/bin/qbportupdater.sh
⚙️ Step 4 – Systemd Service​
Create /etc/systemd/system/qbportupdater.service:
[Unit]
Description=ProtonVPN NAT-PMP Port Updater for qBittorrent
After=network-online.target qbittorrent-nox.service
Wants=network-online.target
[Service]
User=qbittorrent
Group=qbittorrent
ExecStart=/usr/local/bin/qbportupdater.sh
Restart=always
RestartSec=10
StandardOutput=journal
StandardError=journal
[Install]
WantedBy=multi-user.target
Enable and start:
sudo systemctl daemon-reload
sudo systemctl enable --now qbportupdater.service
⚙️ Step 5 – Verify​
Check logs:
journalctl -u qbportupdater -f
You should see:
[2025-09-25 12:07:51] Port changed to 55090, updating qBittorrent
[2025-09-25 12:07:51] qBittorrent listen port updated successfully
📌 Notes & Gotchas​
  • The script logs only when the port changes → keeps journal quiet.
  • Ports rotate roughly every 60 minutes; ProtonVPN requires refreshing every 15–60s, hence the loop.
  • Don’t run this as root. Running under qbittorrent user keeps things tighter.
  • If you change WebUI credentials or port, update /etc/qbportupdater.conf.
  • I tested with UDP, I haven't confirmed if it works with TCP.
That’s it — you now have hands-free ProtonVPN port forwarding with qBittorrent behind Asuswrt-Merlin.
mods - Please can you edit the curl commands for me in Step 3. When I try and paste curl with a -s flag, it refuses to post!
âś–
