AX-11000 - Checking Wireless Connection Rates...
e38BimmerFN
Is there a way to check to see what connection rates are being seen ON the router by chance? I know we can see what devices are connected. I was curious if the AX can show the connection rate per device with the router.
Also if there is a way to show the connection rate while in wireless bridge mode?
Both the Wireless Log and the Networkmap will show you that info.
Thank you.
