AX 110000 Best WIFI + Professional Settings?
Mittenz
Im looking for full settings for 2.4ghz 5.0_1 and 5.0_2 bands.
Can anyone share their settings?
Defaults are the best bet. Use SmartConnect. Enable WPA2/WPA3-Personal if you have WIFI 6 devices. Disable WPS as it can be a security risk. Use DFS. Pretty much let the router and clients choose the channel and bandwidth they want to use. Pushing 160 MHz can lead to disappointments. If you are in a crowded WIFI environment you may want to set the 2.4 GHz to 20 MHz but leave it on auto channel.
This may be contrary to what you and others have done in the past but this is a modern well engineered router! Try it at least.
