AX 160mhz vs 80mhz (battery usage)
leerees
I'm curious if anybody has done any testing on battery usage for 160mhz vs 80mhz AX.
I recently switched down to 80mhz channels and have noticed an increase in battery life on my phone.
It's only been one day so it could just be a coincidence.
I run 160 and I prefer speed over battery since the phone battery is 5000mah it lasts quite awhile anyway.
Phone doesn't have a dual antenna anyway and connects at 1200 but the laptop connects at 2400 and gets real world speed of 1.5gbps.
When on 160mhz, the newer devices get around 950mb/s (1gbps WAN). With 80mhz, it's only 400mb/s.
I can't actually notice any difference in perceived speed (Samsung galaxy s22 ultra and various iphones). Browsing is just as snappy. Netflix UHD starts streaming instantaneously with 400mb/s and scrolling to a different part of a YouTube 8K video is also instant.
Anything I can do to improve battery life on our devices is important. I already have TWT, OFDMA and MUMIMO enabled.
Well, if that extra 2% of battery per day is more important then drop to 80mhz or 40mhz. I move data on the LAN and dropped my Cable 1gbps connection for FWA instead for 1/2 the price and 2-3X the upload speeds.
Signal to noise ratio @80MHz is better. It translates to better range. Your phone needs less transmit power to maintain the connection. Modern mobile devices have sophisticated power management and that includes dynamic radio transmit power adjustment. Your observations are correct.
Hoping to expand a little more on this.
My specific router (RTAX92u) has the following options on the AX band
4x4:4 (160mhz) vs 2x2:2 (80mhz).
How much more power would 4 streams use compared to 2 streams?
Would this extra power usage be mitigated by the fact data is transfered faster?
It's not going to be significant in terms of the power bill if you're asking that.
If you want to go fast then 4x4 is your option. If you are fine with slower speeds then leave it alone.
No. I'm talking about saving battery life on the mobile devices so they last longer between charges.
I was wondering if having more streams caused a noticable drain?
Turn on 160mhz, charge your phone to 100% and use like normal. Go into the battery setting when it gets down to 10% and note the time. Recharge and repeat and compare.
For my use on a 5000mah battery I easily get over a day on WiFi only.
It will vary device to device, but the 160MHz bandwidth setting gives me more battery life with my use of the phone.
Less active WiFi on time = less battery used.
Thanks for the replies. I decided to go back to 160mhz.
As the AX channel is shared with the backhaul, it makes sense to have it connected at 2.4gb/s as this is just over double the speed of my WAN (1gbps).
