Hi All,
I've recently purchased the AX-82U, I had installed this as my main router and now the AC-86U was used as a node (I've also tried setting it as a access point, with same results). The problem is anything connected to the 82U was working fine but anything connected to the 86U was losing connections around every 30-40 mins. Wired and wireless. The log was giving me the error Disassociated because sending station is leaving (or has left) BSS (8) .
Now I did a search an found out the some where along the way Asus changed something and even some on the newer firmwares for the 82U was having this issue. My only solution was to take the ac86u router and use that one as my main router and the new ax82u router as the node since that router is newer and the oldest firmware I could find was around May of this year.
Anyone have any other solutions so I can have the ax-82u as my main, since I'm losing out on some of the features of the router? Or is this something I just have to wait until Asus decided to fix their firmware?
Thanks!
Thanks!
