AX Router for a small appartment
aliitp
so i just moved into a small 1 BR appartment with a balcony and was looking to get an AX router as i have plenty of IT stuff going on here, including but not limited to a Gaming PC, mining RIG, Gaming Laptops and would like to stream on my LED, i also will have a 200 Mbps broadband connection, what AX Router do you guys recommend ? the coverage area is no huge its only an appartment but id like to get the fastest AX router for my apartment, recommendations apprecaited... thanks,
det721
Part of the Furniture
Small APT all you will need is a AX58U. Anything more and you wont notice much bang for the buck.
aliitp
this router u recommended has no AC support ?!?!
also it supports
802.11ax (2.4GHz): up to 574 Mbps
802.11ax (5GHz): up to 2402 Mbps
while the AX86U supports almost double the speed:
802.11ax (5GHz): up to 4804 Mbps
and the AX89X (probably a premium more expensive router) supports:
802.11ax (2.4GHz): up to 1148 Mbps
am in a small apartment YES
but i need something that supports fastest 5 Ghz and 2.4 GHz speeds when connected on a single client, the one u recommended seems lacking ! just because having a smaller house doesnt mean u need to settle to slower router/bandwidth/throughput,
last time i checked here on SNB members recommended me the AX88u is that still a valid option or is it oudated model ??...
thanks,
