Do you mind sharing the external installation of the second antenna link, I went through all the manuals on manualslib.com and I could not find how to do it. I installed an internal one but I think it doesn't do much justice. My Tiny came without a wireless card. Thanks.The Lenovo Tiny user manual that I looked at describes replacing the built-in WiFi adapter but didn't specifically mention which connectors to use - just use the placement that's already there. It also showed where to fix a second external antenna should you choose to do so.
Documentation is here: https://pcsupport.lenovo.com/us/en/...kcentre-m900/10fl/documentation/doc_userguide
This appears to be most useful. See page 132.
https://download.lenovo.com/pccbbs/thinkcentre_pdf/m700_m900_m900x_tiny_hmm.pdf
You model is slightly different from the model I was looking at (M720). For that model they were using one of the two (you appear to have one) optional connector punch-outs to mount a second external antenna.
Even though your model didn't come with a wireless card did it come with the internal antenna cables and the "front Wi-Fi antenna"?
Thread starter | Title | Forum | Replies | Date |
T | Speed and connectivity between wireless antenna and internal router on combination devices | General Wireless Discussion | 3 |
Welcome To SNBForums
