AX86S AIProtection ?
ccps
Just bouoght the unit. First Asus router. Exploring the device and turned on the AIprotection feature (Trend Micro). From what I have discovered online is I should have a place in the firmware update section to update the trend Micro signature. I saw it on a YouTube video but was not sure it was the same model. I am on the latest firmware 3.0.0.4.388_22525. Am I missing this feature? Thx.
bbunge
Part of the Furniture
No. AiProtection will update automatically. You can also manually check by clicking the Check button to the right of Signature Version. Current version is 2.344.
Tech9
Administration, Firmware Upgrade:
ccps
I turned it on just to see what the options were once on. I know these built in add ons are not always benificial. So whats the general concensus. On or off?
Tech9
There is no general consensus. It's a firmware option and some have it ON, others OFF. What you need to know is AiProtection, Apps Filter in Parental Controls, Traffic Analyzer, Apps analyzer, Adaptive QoS and Web history all use 3rd party TrendMicro engine and you have to agree to data sharing to TrendMicro in order to use the options. The modules are closed source and what exactly goes to TrendMicro is not very clear. The attached EULA has a long list of general statements covering more than one product. Similar to free anti-malware software you install on your PC - you have to share some data to receive some services. This is normal and common practice. What I personally don't like is the fact Asus never tells the users there is 3rd party involvement. Only after you buy the router you discover there is data sharing EULA and it applies for widely advertised firmware options.
I personally have one only Asus router in production, it performs limited duties in a remote location and has AiProtection ON. Any of the above options enabled activates TrendMicro data collection daemon and if your "privacy" is top priority you have to keep them all OFF. It's your choice.
ccps
LOL. I was just literally reading about what is collected and what won't work if I go into administration / privacy and withdraw for that particular data collection. Thanks for the heads up.
ccps
I'm going to leave it on. The way things are going these days. Every little bit helps. Not that I am unaware of the intrusiveness of the data collection. At this point I don't know that it's possible to not be collected on at every corner. No matter how much we try to minimize it.
Tech9
It wasn't like sharing a secret with you. The default configuration after factory reset is all TrendMicro components OFF. When user agreement is needed a pop-up screen tells you about it. Google, Apple, Microsoft already know about you as well as your ISP, mobile operators, some IoTs with cameras and microphones people voluntarily install in their homes. Just add TrendMicro to the list.
nickie
I have it on just for peace of mind, in addition to cloudflare and open dns family dns and all browsers with safe browsing on. Since January (the last time I had a clean configuration of the router) I have 0 hits on AiProtection, but will keep it on. Have a teenager at home with friends sending God knows what via the internet, so prefer to keep my network as secure as possible.
Tech9
All modern browsers use Safe Browsing engine and you have to disable it in order to trigger some AiProtection response.
