Anyone knows if I can use ac86u antennas with my ax86 router?
Useful info, just to furthering antenna's question... does you know each antenna of AC86U/AX86U what band will manage?Yes, me. You can use AC86U antennas. AX86U will work in exactly the same way. Tested, see my signature.
Thanks for the info. But in other post someone said the 4th internal antenna manage only 5ghz. So External will be 2.4/5ghz (3x3) and internal only 5ghz (4x4), right?Both 2.4GHz and 5GHz bands for each antennae.
It's clearer now, so the 4th Antenna has less performances than external 3 one's? I don't understand how as example MI-MO can manage a 4th different antenna without loosing performance with clients when 4x4.The 3x external antennas are mostly for marketing purposes. Standard dual-band low gain dipoles close to sphere omnidirectional. The actual antenna part inside the plastic is about 5cm long. The 4th antenna is internal printed on a small PCB.
Thanks for the infoYes, 2.4GHz is 3x3:3 and 5GHz is 4x4:4.
But you only asked about the external antennae.
The internal 4th antennae doesn't have less performance. It is equal. And, furthermore, it is matched to the external antennae otherwise it would decrease the overall performance, not benefit it.
No one have external antenna's, that's true.No, the router will work in a very similar way with 4x printed internal antennas. The sticking plastic outside serves mostly marketing purposes. How many business access points you have seen with external antennas? This is what antennas on a high-end access point look like:
I can only say AX86U-Pro, AX88U and GT-AX11000 share the same problem in my house, 5Ghz just struggles.
Welcome To SNBForums
