AX86U Guest network
Nox34
Have been trying to setup some shellys on my ax86u guest network and nothing works.
As soon as i connect them to the guest network they more or less disapear. I can see that they are connected but i cant see them in the shelly app or use the web ui to connect to them. They get assigned with ip 192.168.100.xx on the guest network and 192.168.50.xx on the regular, is that what messes this up?
have no clue what to do
What firmware is on your AX86U? Do you use a VPN? Any other router configurations?
Try enabling intranet access and see if that makes any difference.
The Guest Network IP address is correct. AiMesh 2.0, that's part of the latest firmware, supports Guest Network 1 on the mesh nodes, so Asus designed it to use the 192.168.100.xx pool to achieve this and not the DHCP IP pool. If you use any of the other Guest Networks, they will use the DHCP IP pool.
