AX86U Hard wired node works but showing disconnected
Nasir Mahmood
Since latest firmware update (388.1). My hard wired node AX86U showing cable disconnected. Cable is connected and works fine. When mesh status is checked on android app. It shows normal. Have both screenshots attached. I have reset both Router and node to factory and setup mesh again, that didn't help either.
aex.perez
Been reported numerous times. Running AX88 and two AX86's had the same issue. Finally stayed on 388 on the AX88 and current ASUS firmware on the AX86's to get past it. At some point it'll get fixed but until it does, this works as well...
