AX86U Merlin latest firmware, openvpn use problem
echoowall
AX86U Merlin latest firmware, openvpn use problem The 2.5G port device connected with the network cable cannot be accessed when using the openvpn program, and the access of other interfaces and wlan interfaces is normal. Below are the traceroute details.
traceroute 192.168.51.200
traceroute to 192.168.51.200 (192.168.51.200), 64 hops max, 52 byte packets
1 * 10.10.10.2 (10.10.10.2) 7.993 ms *
2 10.10.10.1 (10.10.10.1) 8.461 ms 1.663 ms 1.642 ms
3 10.18.0.1 (10.18.0.1) 5.005 ms 4.673 ms 4.608 ms
4 192.168.51.200 (192.168.51.200) 5.162 ms 5.617 ms 5.127 ms
This is a device that cannot be accessed when using the openvpn program to connect, but it can be accessed normally in a local area network environment.
traceroute 192.168.51.5
traceroute to 192.168.51.5 (192.168.51.5), 64 hops max, 52 byte packets
1 10.10.10.2 (10.10.10.2) 5.047 ms * 8.295 ms
2 10.10.10.1 (10.10.10.1) 1.672 ms 2.617 ms 3.507 ms
3 10.18.0.1 (10.18.0.1) 6.092 ms 5.056 ms 4.555 ms
4 * *
The following is the situation of the AX86U routing table. The routing table looks normal.
defaultMy IP0.0.0.0UG000WAN
10.18.0.0*255.255.255.0U000tun21
My IP*255.255.255.255UH000WAN
169.254.0.0*255.255.0.0U000MAN
192.168.50.0*255.255.254.0U000LAN
239.0.0.0*255.0.0.0U000LAN
All of my devices connected to the 2.5G port cannot be connected to the AX86U via openvpn. May I ask what is the problem?
bbunge
Part of the Furniture
Look to the switch connected to that port. My NAS connected to the 2.5 GHZ port can be reached over OpenVPN.
echoowall
I did not use any switches on the 2.5G port. openvpn is a server program that comes with the firmware. How should I troubleshoot it?
echoowall
At the time of ASUS official firmware version 384, it was normal, and I did not change anything after using the Merlin firmware.
